TwinTurbo.NET: Nissan 300ZX forum - Re: Code 14.......
Re: Code 14.......
R3spawnn
on May 06, 2021 at 7:28 PM
Code 14.......
posted by R3spawnn
on May 06, 2021 at 06:48 PM
forgot to mention my speed and odometer work fine but overdrive isn’t working when I press the button nothing happens. Cruise control lights up on the dash when I press button.
Code 14.......
R3spawnn
18:48:59 05/06/21
Re: Code 14.......
R3spawnn
18:57:26 05/06/21
Re: Code 14....... -
R3spawnn
19:28:13 05/06/21
Even tho the speedo is working, that could be where the
Polishzx
20:43:39 05/06/21
Re: Even tho the speedo is working, that could be where the
R3spawnn
21:19:51 05/06/21
Re: Re: Even tho the speedo is working, that could be where the
R3spawnn
21:37:58 05/06/21
Re: Re: Re: Even tho the speedo is working, that could be where the
itsa300zx
22:02:30 05/06/21
Re: Re: Re: Re: Even tho the speedo is working, that could be where the
R3spawnn
22:18:14 05/06/21
Clusters need to match - if it was not from a automatic
12:38:22 05/10/21
R3spawnn
10:11:28 05/08/21
See if techno@comcast.net still works
Zxpress
11:07:33 05/08/21
Re: See if techno@comcast.net still works
R3spawnn
16:24:19 05/08/21
Re: Re: See if techno@comcast.net still works
Zxpress
17:28:27 05/08/21
R3spawnn
21:51:03 05/06/21
CEL light flashing is it reporting a fault code. (n/m)
12:39:29 05/10/21
Re: CEL light flashing is it reporting a fault code.
R3spawnn
15:57:58 05/10/21
Does the "new" cluster have an "auto" light between the
12:40:23 05/10/21
Re: Does the "new" cluster have an "auto" light between the
R3spawnn
15:55:06 05/10/21
The grease is in those connectors on purpose. Don't clean it (n/m)
12:35:50 05/10/21
